Полная версия этой страницы: EVO 6 Kazakhstan
fanat_evo
Характеристики турбинки в студию
Санёчо эво6
This is a Borg Warner S360 Nonextended Tip Turbo. The Nonextended tip turbos work great in lower boost applications and where bang for the buck performance is needed. They still sport the excellent bearing systems that all Borg Warner Turbochargers have and the killer aerodynamic packages to. The NET turbo just give up some flow and are not able to run at high pressure ratios (30+psi) like the extended tip versions.
Turbocharger Name - S360
Compressor Wheel Inducer - 60mm
Compressor Wheel Exducer - 83mm
Turbine Wheel Inducer - 74mm
Turbine Wheel Exducer - 65mm
Horsepower Rating - 350-630
V-Band T3 A/R.70
