RalliArt номера деталюшек для 1-3 поколения |
16.1.2012, 4:12
Front strut insulator RA808306K1
Front lower arm bush (front) RA197684K1 Front lower arm bush (rear) RA130234K1 Upper Front Axle Bush Center Members RA844445K1 Lower front axle bushing member center RA844446K1 Rear Upper Arm Bush (the body) RA809227K2 Rear lower arm bush (the body) RA809239K2 Rear lower arm bush (the body)※1 RA244851K1 Up rubber hardness (optional part) Rear trailing arm bushing RA809262K1 Rear Shock Upper Bush (A) RA242358K2 Rear Shock Upper Bush (B) RA338618K2 Rear Spring pad upper RA809280K1 Front stabilizer bar bushings (φ16) RA197005K1 Rear stabilizer bar bushings (φ18) RA197002K1 Rear differential support member bushing RA844818K1 Rear Diff bushing support arms RA809334K1 Insulator engine & T / M mount RA871602K1 Insulator Engine Roll (front) RA581297K1 Insulator Engine Roll (Rear) RA309269K2 Bush gear shift control RA844835K1 Upper radiator support bushing RA660634K1 Lower Radiator Support Bush RA906101K1 Exhaust Hanger (B) RA906124K1 Super traction rear L.S.D. ASSY RA534828K1 ● ● ●55゜/55゜ -55゜/35゜ <Replacement Parts> Rear LSD friction plates 1.6 RA282104K1 <Replacement Parts> Rear LSD friction plates1.7 RA138432K1 <Replacement Parts> Rear LSD friction plates1.8 RA163449K1 <Replacement Parts> Rear LSD friction disk1.7 RA138433K1 <Replacement Parts> Rear LSD Cam Ring Kit RA192402S1 <Replacement Parts> Cone Spring for initial adjustment 1.5 RA79240GK1 <Replacement Parts> Cone Spring for initial adjustment 1.7 RA792400K1 <Replacement Parts> Cone Spring for initial adjustment 2.0 RA783801K1 Sports radiator cap (black) RA660667N1 Sports Radiator Cap (Red) RA660667N3 Sports Thermostat RA351591N1 Clutch disc RA030102K1 Clutch cover RA731270K2 Operating system architecture Consequences Sport Kit RACE9501S1 Sports Triple Meter Kit 1DIN RA517925S1 Racing platinum-iridium spark plugs RAR7376N9P Enhanced Cylinder Head Bolt Set RA191470S1 Full bucket seat sports driving (RECARO) Black※2 RA081829S1 Hotsu driving device Full Bucket Seat (RECARO) Red / Black※2 RA081830S1 Dedicated sports driving full bucket seat rail (driver side)※2 2083.017.2 Dedicated sports driving full bucket seat rail (passenger side).※2 2083.017.1 Full Bucket Adapter sports driving side (sheet 1 minute)※2 1700000J Black sport bucket seats※3 RA652303S1 Red sport bucket seats※3 RA652304S1 Sport bucket seats, driver's seat rails only ※3 RACP9701S1 Sport bucket seats front passenger seat rails only ※3 RACP9702S1 |
16.1.2012, 17:25
Operating system architecture Consequences Sport Kit RACE9501S1 - это что?
переводов бы для второй половины (первая половина понятно - резинки). и еще, где это заказать то можно? на экзисте либо не находит, либо цен нет. не то чтобы я покупать что-то собрался... |
16.1.2012, 18:27
Партнер клуба Группа: Партнер клуба Сообщений: 1011 Регистрация: 11.3.2006 Из: Москва |
Мы возим RA
26.1.2012, 13:10
то есть купить все это счастье можно только через эво партс?
каталог с цена имеется? |
16.7.2012, 16:55
Подниму тему!Цены интересны!
18.7.2012, 4:03
18.7.2012, 4:07
RA363571N2 Thermostat 76°C £57,79
RA403282K1 Insulator, front strut(top mount)Hs90 £48,15 RA197684K1 Bushing, front lower arm,front,Hs70 £19,26 RA130234K1 Bushing, front lower arm, rear,Hs90 £38,52 RA844456K2 Bushing, front stabilizer,23mm,Hs90 £14,45 RA242358K2 Bushing, rear shock, upper(A)Hs90 £13,48 RA338618K2 Bushing, rear shock, upper(B)Hs90 £13,48 RA856469K1 Bushing, rear stabilizer, 21mm,Hs90 £16,86 RA856461K1 Bushing, rear upper arm(body/front)'90 £25,04 RA856464K1 Bushing, rear upper arm (body/rear.)'90 £17,34 RA856440K1 Bushing, rear lower arm(body)Hs90 £17,34 RA244851K1 Bushing, rear lowerarm (shock)Hs90 £17,34 RA864730K1 Bushing, rear trailing arm(body)Hs90 £28,89 RA369384K1 Bushing, rear diff. support insulator, for RS model, Hs90 £18,30 RA809334K1 Bushing, rear diff. support arm, Hs90 £15,41 RA171989K1 Insulator, engine & t/m mtg, Hs90 £31,78 RA197518K1 Insulator, engine roll(front) Hs90 £31,78 RA369343K1 Insulator, engine roll(rear) Hs80 £31,78 RA844835K1 Bushing shift control, Hs90 £7,70 RA266941K1 Bushing, radiator support,upprHs90 £11,56 RA906101K1 Bushing, radiator support lwr, Hs90 £11,56 RA906124K1 Muffler hanger, B, Hs90 £13,48 RA651790K1 Mufflerhanger, D, Hs90 £19,26 RA316999K1 Bush steering rack £28,89 |
18.7.2012, 11:45
19.7.2012, 5:12
Полный комплект резинок во все рычаги, подушки двигателя тоже интересуют. Опоры стоек передних.
19.7.2012, 8:08
19.7.2012, 10:25
25.7.2012, 1:46
Полный комплект резинок во все рычаги, подушки двигателя тоже интересуют. Опоры стоек передних. http://injapan.ru/auction/c311974124.html |
31.7.2012, 10:54
а это работает? какие сроки и что в итоге? |
31.7.2012, 16:27
1.8.2012, 4:28
Там всего в 4 рычага и втулки стабов есть.
17.8.2012, 19:08
18.8.2012, 6:24
Как оказалось-уже нет:(
18.8.2012, 10:41
18.8.2012, 15:27
Где его хоть брать? Нашёл только X5 в экзисте!
18.8.2012, 16:09
Текстовая версия | Сейчас: 27.4.2024, 16:02 |
