Сравнение характеристик всех моделей, С 1 по 10 |
![]() Зарегистрированный пользователь ![]() Группа: Пользователь Сообщений: 1715 Регистрация: 22.6.2006 ![]() |
Короче вот собрал характеристики в одной таблице.
Выходит самый сильный в истории эво был 3 RS, а самый слабы 10 на роботе. Evolution I GSR Weight [kg]: 1240 RS Weight [kg]: 1170 Power [bhp]: 247 Torque [lb/ft]: 228 Power-to-weight ratio [hp/ton]: GSR:199,19 / RS:211,11 0-60mph: 5.1 secs 0-100mph: 13.7 secs Top Speed [mph]: 143 Evolution II GSR Weight [kg]: 1250 RS Weight [kg]: 1180 Power [bhp]: 257 Torque [lb/ft]: 228 Power-to-weight ratio [hp/ton]: GSR:205,60 / RS:217,79 0-60mph: 5.0 secs 0-100mph: 13.5 secs Top Speed [mph]: 147 Evolution III GSR Weight [kg]: 1260 RS Weight [kg]: 1190 Power [bhp]: 266 Torque [lb/ft]: 228 Power-to-weight ratio [hp/ton]: GSR:211,11 / RS:223,53 0-60mph: 4.9 secs 0-100mph: 13.3 secs Evolution IV GSR Weight [kg]: 1350 RS Weight [kg]: 1260 Power [bhp]: 276 Torque [lb/ft]: 260 Power-to-weight ratio [hp/ton]: GSR:204,44 / RS:219,04 0-60mph: 4.8 secs 0-100mph: 12.9 secs Top Speed [mph]: 150 Evolution V GSR Weight [kg]: 1360 RS Weight [kg]: 1260 Power [bhp]: 276 Torque [lb/ft]: 275 Power-to-weight ratio [hp/ton]: GSR:202,94 / RS:219,04 0-60mph: 4.8 secs 0-100mph: 12.9 secs Top Speed [mph]: 155 Evolution VI GSR Weight [kg]: 1360 RS Weight [kg]: 1260 Power [bhp]: 276 Torque [lb/ft]: 275 Power-to-weight ratio [hp/ton]: GSR:202,94 / RS:219,04 0-60mph: 4.8 secs 0-100mph: 12.9 secs Top Speed [mph]: 155 Evolution VI TME GSR Weight [kg]: 1360 RS Weight [kg]: 1260 Power [bhp]: 276 Torque [lb/ft]: 275 Power-to-weight ratio [hp/ton]: GSR:202,94 / RS:219,04 0-60mph: 4.8 secs 0-100mph: 12.9 secs Top Speed [mph]: 155 Evolution VII GSR Weight [kg]: 1400 RS Weight [kg]: 1320 Power [bhp]: 276 Torque [lb/ft]: 282 Power-to-weight ratio [hp/ton]: GSR:197,14 / RS:209,09 0-60mph: 4.7 secs 0-100mph: 12.7 secs Top Speed [mph]: 155 Evolution VIII GSR Weight [kg]: 1380 RS Weight [kg]: 1300 Power [bhp]: 276 Torque [lb/ft]: 289 Power-to-weight ratio [hp/ton]: GSR:200,00 / RS:212,30 0-60mph: 4.5 secs 0-100mph: 12.5 secs Top Speed [mph]: 160 Evolution IX GSR Weight [kg]: 1410 RS Weight [kg]: 1320 Power [bhp]: 276 Torque [lb/ft]: 295 GSR / 300 RS/GT Power-to-weight ratio [hp/ton]: GSR:198,56 / RS:209,09 0-60mph: 4.4 secs 0-100mph: Uknown Top Speed [mph]: Unknown Evolution X GSR Weight [kg]: 1595 MR Weight [kg]: 1630 Power [bhp]: 291 Torque [lb/ft]: 300 Power-to-weight ratio [hp/ton]: GSR:182,44 / MR:178,53 0-60mph: 4.9 secs 0-100mph: Uknown Top Speed [mph]: Unknown |
![]() Зарегистрированный пользователь ![]() Группа: Пользователи Сообщений: 504 Регистрация: 19.11.2007 Из: мичуринск ![]() |
Да - каждый эво по своему хорошь
![]() Зарегистрированный пользователь ![]() Группа: Член клуба Сообщений: 1090 Регистрация: 6.10.2008 Из: Москва ![]() |
Самый слабый эво 10 на роботе едет быстрее эво 10 на ручке :(
![]() Зарегистрированный пользователь ![]() Группа: Пользователь Сообщений: 350 Регистрация: 12.2.2008 Из: СПБ ![]() |
значит я ездею на самом слабом эвике -даааа, а интересно есть данные допустим времени на Мячково стандартной шестёрки и стандартной девятки на стоковом давление и на стандартной резине
![]() Зарегистрированный пользователь ![]() Группа: Пользователь Сообщений: 1172 Регистрация: 10.2.2008 Из: Владивосток ![]() |
тройка, не самый сильный эвик....
да, легкий... но разгон у семерки точно лучше (сравниваю свой 3 РС и 7 ГСР) |
![]() Зарегистрированный пользователь ![]() Группа: Пользователь Сообщений: 327 Регистрация: 25.4.2007 Из: Кемерово ![]() |
автор видимо имеет ввиду мощность/вес. тогда да, у 3ки рс соотношение лучшее. но вот только это не говорит что она самая быстрая.
а вообще это путь эволюции тд05, не считая последней версии.
автор видимо имеет ввиду мощность/вес. тогда да, у 3ки рс соотношение лучшее. но вот только это не говорит что она самая быстрая. именно про это я и говорил. я думаю что данное знаение имеет огромное влияние на динамику автомобиля. кстати у нас в казахстане сейас самый быстрый эво, именно третий, время на квотере 11,4. |
данный робот кот стоит сщас наХ конечно не преднозначен для низких стартов но со временем я думаю их научатся усиливать (тем более что все основные проиводители массовых спорт каров уже переходят на такие же коробки) и вскором коробки на ручках стануть класикой и будут всречатся всё реже и реже...... прогрес не остановить
данный робот кот стоит сщас наХ конечно не преднозначен для низких стартов но со временем я думаю их научатся усиливать (тем более что все основные проиводители массовых спорт каров уже переходят на такие же коробки) и вскором коробки на ручках стануть класикой и будут всречатся всё реже и реже...... прогрес не остановить ну может быть. а пока ручка рулит. |
![]() Смотрящий ![]() Группа: Член клуба Сообщений: 7492 Регистрация: 15.4.2006 Из: Москва ![]() |
ну может быть. а пока ручка рулит. +10000 !!!!! И дело не только в быстроте..... Для меня ручка это еще один источник информации из которой и формируется чувство автомобиля в целом !!!!! Аффтомат или ропот этого не дают !!!! Даже на Порше с их инженерией машинка на ручке мне показалась приятней.... Что уж про митсуписи то говорить)))) !!!!! Компромис это тольо нах он нужен на таких машинках убейти меня не пойму.....((( |
![]() Зарегистрированный пользователь ![]() Группа: Член клуба Сообщений: 6133 Регистрация: 15.4.2007 Из: Санкт-Петербург ![]() |
Взвешивали и 7, и 8, и 9.
Если 7 действитнльнно весит 1400, то у 8,9 никакими 1400 даже не пахнет ~ 1500кг. |
![]() Зарегистрированный пользователь ![]() Группа: Член клуба Сообщений: 3129 Регистрация: 27.7.2007 Из: Москва ![]() |
я чет не врубаюсь...эт таблица для каких эво---япа...америка...европа..?
в 8ке европа ну никак не 276 сил! а 265... и +1 к ОМу веса машин чёт какие-то маленькие... |
я чет не врубаюсь...эт таблица для каких эво---япа...америка...европа..? в 8ке европа ну никак не 276 сил! а 265... и +1 к ОМу веса машин чёт какие-то маленькие... все веса брались с паспортных данных. естественно что вес на самом деле выше. например таже десятка GSR в действительности весит около 1640 кг. лошади также брались из пасспортных данных для японских машин. если где то ошибки, поправьте. |
![]() Зарегистрированный пользователь ![]() Группа: Пользователь Сообщений: 3512 Регистрация: 5.5.2009 Из: Москва ![]() |
скажите, а это правдивые паспортные данные ? 8ка действительно едет в стоке за 4.5 секунды ?
![]() Зарегистрированный пользователь ![]() Группа: Член клуба Сообщений: 1574 Регистрация: 11.10.2007 Из: Ленинград ![]() |
все веса брались с паспортных данных. естественно что вес на самом деле выше. например таже десятка GSR в действительности весит около 1640 кг. лошади также брались из пасспортных данных для японских машин. если где то ошибки, поправьте. все правильно это вес ипонских машин. |
![]() Зарегистрированный пользователь ![]() Группа: Член клуба Сообщений: 3497 Регистрация: 17.4.2008 Из: М.О. Красногорск ![]() |
Текстовая версия | Сейчас: 16.6.2024, 10:13 |
