Оригинальные номера детали EVO 1, 2, 3(I, II, III) |
4.3.2012, 14:54
Полный комплект Прокладок:
MD971914 Gasket set, engine overhaul MD192031 Gasket, inlet Головка Блока Цилиндров: MD327728 Headassy,eng.cylinder (MD334948) MD191470 Bolt, cylinder head (11 x 97) MD130164 Valve, exhaust MD127840 Valve inlet MD139243 Valve spring MD016483 Valve collet MD126605 Guide inlet valve MD126608 Guide exhaust valve Блок двигателя: MD350928 Block assy, cylinder MD326349 Bearing, crankshaft, Std. MD343186 Bearing, crk.ctr,Std.SO(MD326354) MD351820 Thrust bearing set MD153368 Bolt, cylinder block (7pcs,10x70) MD177374 Bolt, cylinder block (1pc, 10x70) MD183236 Bolt, cylinder block (2pcs, 10x70) Cover, rear plate, oil pan: MD324053 Plate, cyl.block baffle MF660034 Gasket, cyl.block MD332043 Pan assy, engine oil Поршень и Коленвал: MD346024 Crankshaft MD193029 Bolt, conrod MD326359 Bearing, conrod, Std., MD193027 Con-rod assy MD144215 Nut, conrod MD326340 Piston assy., std. Evolution 3 MD313405 Ring set to suit Evo.2/3 piston MD313406/7 Ring set, oversize MD194278 Flywheel MD030629 Ring gear MD313286 Piston assy, std. Evolution 2 MD130704 Bolt MD302074 Bolt, flywheel MD326059 Belt, valve timing (MD327394) Распредвалы и Клапана: MD170799 Camshaft sprocket MD343085/ Camshaft MD310858 Camshaft Cover MD191805 Cover, timing belt MD191807 Cover, timing belt MD182295 Balancing belt MF241230 Bolt, rocker cover Охлаждение: MD075834-9MM O RING dipstick tube seal Oil Pump & Oil Filter: MD135737 Oil filter Oil cooler tube: MB890995 Oil cooler radiator, engine MB890992 Hose kit, oil cooler MB033025 Eyebolt, oil cooler line (16x33) MD191710 Oil filter bracket assy Топливо: MR179186 Pump & gauge assy, fuel tank Инжектора и Дроссельная заслонка: MD189326 Regulator, MPI delivery pipe press. MD322173 Throttle body MD187380 Injector, fuel MB658689 Fuel filter Engine Control: MR103557 Cable, accelerator MD085014 ALS Valve MD113721 Fuel pressure valve MD145201 Boost valve Охлаждение Radiator,Hose&Condenser Tank: MB890505 Radiator assy (MB890506) MB890991 Hose, radiator, lower MB890990 Hose, radiator, upper MB906056 Shroud, cooling fan MB845001 Fan, cooling MB924970 Motor, cooling fan MD182467 Sensor, water temp MD972050 Water pump kit MD186125 V-ribbed belt, water pump/Alt. MD030764 'O' Ring Впуск и Выпуск: MD620737 Air cleaner element MD183609 Sensor, air cleaner air flow Турбина: MD171221 Seal ring, T/C MD185805 Gasket, T/C exhaust outlet fitting MD171220 Gasket, T/C exhaust gas inlet hole MR187848 Washer, T/C(coned disk,10.5) MR187699 Bolt, T/C (10x80) MD184826 Actuator, T/C wastegate MR239346 Turbocharger, sub assy MR239663 Gasket, exhaust manifold MD189460 Gasket, T/C air out fitting MD067956 Bolt, exhaust manifold MB924442 Intercooler Assy MD197463 Hose, intercooler MD195745 Hose, intercooler MD184729 Hose, intercooler MD187845 Hose, intercooler MD197465 Hose, intercooler MD302862 Hose, intercooler air MD301582 Hose, intercooler MD613626 Turbo housing MD183650 Turbo oil return pipe Exhaust Pipe & Muffler: MR224103 Exhaust pipe, front MB687004 Exhaust gasket MB687002 Gasket, exhaust pipe Secondary Air Supply: MR239118 Valve, secondary air supply Электрика Двигателя: MD172860 Starter assy, 1.2KW Alternator & Vacuum Pump: MD153843 Alternator, 90Amp MD190819 Alternator, 75A Electrical Control: MD192126 Coil, ignition MD192127 Transistor, ignition power MD184529 Sensor, engine crank angle MD614662 Throttle position sensor MD195229 Ignition lead set MD099628 Resistor, injectors Сцепление: Clutch & Clutch Release: MD719925 Bearing, clutch release (MD749998) MD748125 Clutch cover MD745530 Clutch disc MF473492 Bolt,cylinder ass, clutch master MB012161 Cylinder kit, clutch master Clutch Control: MR297525 Clutch master cylinder (MB555413) MD745508 Cyl assy, clutch release(MD770488) MD972448 Cylinder kit, clutch release Коробка Передач: MD974293 Transmission assy MD748833 Transfer assy MD997740 Liquid gasket, M/T 21090 01 M/T Gear: MD747888 Input shaft MD747250 3rd gear MD747376 4th gear MD707184 Oil seal MD719710 Oil seal MD741818 Oil seal, input shaft MD745477 Synchro ring MD745892 Synchro ring MD746435 Ring assy, M/T 2nd gear MD746439 Ring, input shaft MD747255 Synchro ring MD732314 Bearing, input (MT372041) MD736643 Bearing, M/T diff. case MD736638 Bearing, M/T intermediate Gear MD736641 Bearing, M/T intermediate gear MD736642 Bearing, M/T input shaft MD720948 Spacer MD720949 Spacer, M/T output shaft MD720951 Spacer, M/T output shaft MD720953 Spacer, M/T output shaft MD720955 Spacer, M/T output shaft MD720958 Spacer, M/T output shaft MD720961 Spacer, M/T output shaft MD727658 Spacer, M/T output shaft MD727659 Spacer, M/T output shaft MD727660 Spacer, M/T output shaft MB185360 Shim set, pinion front MB185350 Shim set, pinion rear MB241903 Spacer set MB044434 Spacer, pinion bearing MA180841 Spacer, pinion bearing MD707184 Oil seal, side bearing MB393929 Oil seal diff.pinion MD743361 Output shaft M/T Gearshift Control: MB948584 Gearshift cable set MD723202 Oil seal, transfer box MD701430 Oil seal transfer box MD743421 Nut T/F MD731948 Nut M/T power train Трансфер: MD747991 Spacer, T/F MD749819 Spacer, T/F MD746950 Spacer, power train MD746745 Bearing,T/F driven shaft gear MD728354 Bearing PROPELLER SHAFT MB661722 Shaft assy, propeller(MB919106) MB837576 Propshaft centre bearing MB837576 Propshaft centre bearing Передние привода: MB936359 Shaft assy, Fr. axle drive LH MR165842 Shaft assy, Fr. axle drive RH MB526696 Shaft, Fr.axle, inner MB526956 Bearing kit, front axle shaft MB297732 Spacer, fr.axle MB297860 Bolt, Fr. axle MF450406 Washer, Fr. axle MR222634 Boot kit, driveshaft, front outer MB937307 Boot kit, driveshaft, front inner Front Axle Hub & Drum: MR171013 Knuckle, LH MR171014 Knuckle, RH MB948962 Hub assy, Fr.wheel MB573309 Oil seal, fr.wheel hub,inner MB303875 Oil seal,fr.wheel hub, outer MB303868 Snap ring, Fr. wheel hub MB950886 Disc, Fr.brake MB303865 Bearing, fr.wheel hub REAR AXLE Rear Axle Differential: MR162904 Carrier assy, rear diff. MB664603 Cover, rr.diff.carrier MR166619 Differential kit, LSD MB160496 Disc, rr.LSD, friction MB160497 Disc, rr.LSD, friction MB160500 Plate, rr.LSD, friction MR195402 Plate, rr.LSD, spring Задние Привода: MR195538 Joint & shaft kit, rear axle MB620942 Joint kit, rear shaft, LH/RH MB109029 Nut, rear axle driveshaft MB109025 Washer, rear axle driveshaft MB620943 Boot kit, driveshaft, rear outer MR196877 Boot kit, driveshaft, rear inner Rear Axle Hub & Drum: MB864997 Hub assy, rear wheel MB663547 Bearing rear wheel hub MB663832 Snap ring, rear wheel hub MB699289 Disc, rear brake Передняя подвеска Front Susp. Arm & Member: MR223711 Member, front axle center MR171038 #######member, Fr.axle No.1 RA171038N1 #######member, Fr.axle No.1 LHD MR171042 Stabilizer bar, front (anti-roll bar) MR179115 Arm assy,fr.susp.lwr.LH MR179116 Arm assy, fr.susp.lwr.RH MR131680 Link,fr.susp.stabilizer MR171442 Bracket, front ARB Задняя подвеска Rear Suspension: MB844911 Member, rr diff upper MB809315 Support, rr.diff.,rear MB844918 Bolt,rr.diff.mounting(12x70) MB515260 Bolt,diff.,rear support mounting MR171994 #######member,rr.suspension MR197603 Link assy,rr.susp.assist MR197004 Bracket, rear ARB MR197609 Arm assy.rr.suspn.Lwr.LH MR197610 Arm assy.rr.suspn.Lwr.RH MR102055 Arm assy.rr.suspn.trailing LH MR102056 Arm assy.rr.suspn.trailing RH MF240082 Bolt,rr.suspn.upr.arm MB809345 Bolt.ind't.rr.suspn.arm MF240081 Bolt,rr.suspn.assist link MB809335 Bolt,rr.suspn.lower arm MB809338 Plate,rr.suspn.lwr.arm MB809354 Link assy.,rr.suspn.,stabilizer bar Тормоза Парковочные колодки: MB806052 Cable, parking brake, Rr. MB806053 Cable, parking brake, Rr.RH MB520216 Retainer, parking brake cable Передние тормоза: MB950176 Caliper kit, Fr.brake, LH MB950177 Caliper kit, Fr. brake, RH MB857840 Seal kit, Fr. brake caliper pistons MB151403 Bolt, Fr. brake caliper mount MF450407 Washer, Fr. brake caliper mount MB928049 Front brake pad set (MR389544) Задние тормоза: MR205148 Caliper kit, rr. brake, LH MR205149 Caliper kit, rr. brake, RH MB857875 Seal kit, rr.brake caliper MB699304 Adaptor, rr.brake caliper, LH MB699305 Adaptor, rr.brake caliper, RH MB928314 Rear brake pad set (MR389565) Power Brake Booster: MR129408 Booster assy., brake Brake & Clutch Pedal: MB911453 Member, pedal support(MB911452) MB807211 Pedal, brake Brake Master Cylinder: MB699543 Cylinder assy.,brake master MB928457 Cylinder kit, brake master (15/16") Рулевая рейка Steering Gear: MR171023 Gear & link assy, P/S (strg.rackasy) MB912076 End assy, tie rod MR130807 Tie rod, steering MB350581 Bellows, steering gear 37-110 Power Steering, Oil Pump: MR171022 Oil pump assy, P/S (type B) MR103363 Seal kit, P/S oil pump MD184363 V-belt, P/S oil pump (640mm) Power Steering, Oil Line: MB870010 Hose, P/S oil pressure MR198059 Tube, P/S oil cooler MB815094 Reservoir Кузов Front Bumper & Support: MR208675 Face kit, bumper MB907803/4 Side sill,ft.floor,outer, LH/RH MR236036 Reinforcement, fr.bumper (mt.bar) MR236035 Net, fr.bumper (MB909093) MR236033 Net, grille MR236033/34 Net, ft.bumper,LH/RH Rear Bumper & Support: MR208676 Face kit,rr.bumper,wte(MR162626) MB826710 Reinforcement, rr.bumper MR236218 Air dam, rr.bumper side, LH MR236223 Air dam, rr.bumper side, RH MB945090 Hood (bonnet) Fender & Front End Cover: MB945121 Fender, fr.,LH (MB861663) MB945122 Fender, fr.,RH Front End Panel: MB945077 Panel, support assy. headlamp MB945084 Panel, h/lamp support, lower MR178183 Fender,shield (inner wing/chassis leg-MR178184/85) MB945077 Support panel Windshield Glass & Moulding: MR743075 Glass, windshield (green) MR109930 Spacer, windshield MB292508 Dam, windshield MB696789 Moulding, windshield, upper Roof & Lid: MB835969 Roof panel Side Structure: MB835899 Pillar, ft.outer, LH MB835900 Pillar, ft.outer, RH MB835903/4 Quarter panel, outer, LH/RH MB696803 Roof moulding, LH MR236208 Panel, air dam skirt (front splitter) MR178187/ Sidemember assy, ft.LH/RH Rear End Structure: MB861645/46 Panel, rear door, LH/RH Задние стекло и молдинг: MR743081 Glass, rear window (green) MB814156 Spacer, rr.window MB814159 Dam, rr. window (MB292508) MB696794 Moulding, rr.window, lower MB696792 Moulding, rr.window, upper MB814176 Clip, rr. window moulding Trunk Lid & Lock: MB945092 Panel, trunk lid Двери Передние двери и стекла: MR179645 Panel assy, front door, LH MB797788 Trim panel MB907785 Panel assy, rr. door, LH MB794095 Glass, ft. door, LH MB819551 Handle front door, outside, LH MB819552 Handle front door, outside, RH MB819558 Handle, rr.door outside, RH MB861633/34 Panel, front door, LH (skin) Экстерьер Side Garnish & Moulding: MR208677 Air dam kit, side, LH 62209L 01 £265.84 MR208678 Air dam kit, side, RH 62209R 01 £265.84 Задний багажник и спойлер: MR747453 Air spoiler, rear Внешние зеркала: MB696939 Mirror assy., door, LH MB696940 Mirror assy., door, RH MB696853 Mirror & holder, LH MB696854 Mirror & holder, RH Mud Guard, Shield & Stone Guard: MB959647 Shield kit, splash, fr.LH (rear) MR178797 Shield kit, splash, fr.LH (front) MB959648 Shield kit, splash, fr.RH (rear) MB178798 Shield kit, splash, fr.RH (front) MB907181 Shield kit, splash, rear, LH MB907182 Shield kit, splash, rear, RH MB889067 Cover, engine room under, LH 54 CHASSIS ELECTRICAL Front Exterior Lamp: MR108013 Headlamp, body, LH MR108014 Headlamp, body, RH MB821171 Lamp assy, turn signal, fr.side MR221701 Lamp assy,turn signal,frt.LH(orange) PARTS LISTING MITSUBISHI LANCER EVOLUTION III MR221702 Lamp assy,turn signal,frt.RH(orange) Rear Exterior Lamp: MB907245 Lamp kit, combination, rear LH MB907246 Lamp Kit, combination, rear RH MB859305 Lamp, rr.combi. MR221543 Lamp assy, high mounted stop Windshield Wiper & Washer: MB881331 Arm assy, windshield wiper(dvr) MB881333 Arm assy, windshield wiper(psgr) MB912105 Blade set, windshield wiper(425/500) Switch & Cigar Lighter: MR109195 Intercooler washer nozzle MB802341 Switch column (MB802345) MB926917/18 Hinge MR700987/92 Garnish hood LH/RH(bonnet air outlets)[/quote] Miscellaneous parts and numbers: EvoII tyre placard sticker part number MR197129 Blank Key MB852312 CD/CE9ATiming belt MD326059 CD/CE9A Balance Belt MR984778 MITSUBISHI LANCER EVO 2 3 CE9A PARTS EVO 2 3 CE9A - Engine & Ancilliary Parts MD184826 Actuator for Turbo MD193384 MD327450 Oil Pump MD176245 Lambda Sensor- Oxygen Sensor MD192126 Coil Pack MD614568 MD628054 MD614368 MD628051 Speed Controller - Stepper Motor MD971914 Complete Engine Gasket Set MD172860 Starter Motor MD192127 Ignition Failure Sensor/ Ignitor MD614488 12/93 to 08/94 MD614662 09/94 to 08/95 Throttle Position Sensor MR103556 RH Engine Mount MD376609 MD300516 Crank Pulley MD308587 Hydraulic Cambelt Tensioner MD149309 MD337687 MD377054 MD377054 EVO Lash Adjusters - Tappets x 16 - FULL SET 3mm Type MD313405 Acralite Piston Ring Set MD327394 MD334548 MD352473 MR984778 MD156604 Evo 2 3 Cambelt / Timing Belt Kit MD300516 MD376609® Pulley Crank shaft MB911718 LH Engine Mount MD195229 Standard Plug Leads MD192126Single Coil Pack MR103554 Front Engine Mount MR103555 Rear Engine Mount MD183808 Head Gasket Only MD124762 MD135005 Bottom Toothed Idler Pulley MD998767 Cambelt Tensioner Adjustment Tool Rocker Gasket & Plug Seals MD186784 Rocker cover gasket - MD186785 MD194890 Plug Cover Cambelt 24312-33110 24312-33120 24312-33130 24312-33140 24312-33150 24312-33160 MD326059 MD110029 MD133115 MD145713 MD171748 MD182291 MD326059 MD156604 Upper Cambelt Idler Wheel MD343563 MD069949Crank Oil Seal - Cambelt Side Crank Thrust Bearing MD343329 - S0 MD343330 - S1 MD343331 - S2 MD343332 - S3 MD343333 - S4 MD195925 - S5 MD343186 - S0 MD343187 - S1 MD343188 - S2 MD343189 - S3 MD343190 - S4 MR239663 RA Exhaust Manifold Gasket MD181032 Exhaust Manifold Gasket MD182537 MD334548 MD369999 Cambelt Tensioner MD136466 MB658689 MR571472 AIR / OIL / FUEL FILTER KIT MD174940 MD359158 MD150161 Crank Shaft Oil Seal - Gearbox Side Main Crank Bearings - EVO 2 3 MD316497 - S0 MD195916 - S1 MD195917 - S2 MD195918 - S3 MD195919 - S4 MD195920 - S5 MD326349 - S0 MD326350 - S1 MD326351 - S2 MD326352 - S3 MD326353 - S4 MD171220 Turbo To Manifold Gasket MD352473 MD115976 Balance shaft belt tensioner MD177572 MD182467 Engine Coolant Temperature Sender MD326359 MD326360 MD326361 Big End Shells MD192031 Inlet Manifold Gasket Balance Shaft Belt 23356-33110 23356-33120 23356-33130 23356-33140 23356-33150 23356-33160 MD115977 MD145716 MD171749 MD182295 MD186125 Alternator Belt Oil Pressure Switch MD185805 Turbo To Downpipe Elbow Gasket MD050536 Half Moon Seal - Rocker Cover to head ECU Serial numbers 5663 = Lancer RS 7377 = Lancer GSR 7737- Gsr RS 5537 - Gsr 97162B = MB619605 Tri-Diamonds badge 71822 = MB944988 Bracket radiator grill mark 71992 = MF456097 Screw exterior mark MB909153 Hood insulator, cd/ce9a, (alloy under bonnet heat shield) Blueprint Part Numbers For Mitsubishi Lancer Evolution I,II & III oil filter-adc42112 air filter-adc42224 fuel filter-adc42320 spark plug-w20epzu(evo1)-iw22(evo2/3) timing belt-adc47512 timing belt tensioner-adc47615 balance shaft belt-adc47509 balance shaft tensioner-adg07616 rocker cover gasket-adc46730 head gasket set-nya46272 engine gasket set-adc46272 front pads-adc44250 rear pads-adc44244 front disc-adc44333 rear disc-adc44384 lh front caliper-adc44833 rh front caliper-adc44834 lh rear caliper-adc44535 rh rear caliper-adc44536 lh front hose-adc45332 rh front hose-adc45332 lh rear hose-adc45343 rh rear hose-adc45343 lh handbrake cable-adg04667 rh handbrake cable-adg04668 clutch kit-adc43085 clutch disc-adc43139 clutch cover-adc43246n realease bearing-adc43301 clutch master-adc43413 starter motor-adg01201(evo1) adc41214(evo2/3) alternator-adg01108(evo1) adc41126(evo2/3) oil pressure switch-adt36601 stepper motor-adc47430 water pump-adc49128 thermostat-adc49205 rad cap-adm59903 inner cv boot kit-adc48155 front wheel bearing-adc48205 rear uj kit axle-adc43901 rear uj kit gearbox-adc43901 lh track rod end-adc48703 rh track rod end-adc48703 inner track rod-adc48745 stabiliser link(evo2/3)-adc48505 |
4.3.2012, 17:45
это конечно круто, но к примеру какая прокладка под гбц имеется ввиду? бывают многослои металлические, а бывают и паранитовые...
5.3.2012, 14:40
Металлическая 4-х слойная - MD 349347(Себе такую поставил, хороша))))
5.3.2012, 15:24
у меня такая же. вот это полезный part number. :)
6.3.2012, 4:53
6.3.2012, 5:06
Зарегистрированный пользователь Группа: Пользователь Сообщений: 265 Регистрация: 8.4.2010 Из: ИРКУТСК |
Молодец спасибо!
7.3.2012, 9:32
номерок синхронизатора задней передачи подскажите
коробас эво3 |
10.3.2012, 5:37
номерок синхронизатора задней передачи подскажите коробас эво3 что то я вообще не могу найти синхрон задней передачи, если разобрал посмотри в каталоге http://mitsubishi.epcdata.ru/lancer/ce9a/s...ssion/m-t-gear/ |
10.3.2012, 8:35
Если мне память не отшибло - задняя без синхрона. :-)
10.3.2012, 8:44
10.3.2012, 8:46
что то я вообще не могу найти синхрон задней передачи, если разобрал посмотри в каталоге http://mitsubishi.epcdata.ru/lancer/ce9a/s...ssion/m-t-gear/ похоже на это MD746439 http://mitsubishi.epcdata.ru/lancer/ce9a/s...m-t-gear/63785/ |
16.3.2012, 12:43
похоже на это MD746439 http://mitsubishi.epcdata.ru/lancer/ce9a/s...m-t-gear/63785/ ну так чего все молачт? оно не оно? этот синхр должен упираться в заднюю крышку коробку в средней части. По крайней мере у меня так |
16.3.2012, 18:00
18.11.2012, 9:42
это скорее сюда , чтобы не офтопить в теме раллиарт
мне оказывется тоже надо все подухи двигателя и передние сайленты перед рычагов . евопартс нормальную цену показывал на опоры п.стоек. может потому и поддон мял последнее время , что подухи мёртвые. цены на оригинал на сегодняшний день MR103555 задняя 2200 MR103554 передняя на лыже 2000 MB911718 левая 3500 MR103556 – подушка двиг.правая 5138 нояб.2012 номер на сайленте,которые на лыже и что поменьше MB 309269 , 1400 оригинал и 360 руб РБИ MB581291 - на , что чуть больше - в экзисте не бьётся и негугится |
18.11.2012, 10:04
Цитата MB581291 - на , что чуть больше - в экзисте не бьётся и негугится MB581297 в экзисте не бьётся , но гуглится и как подушка втч |
17.3.2013, 15:24
17.3.2013, 15:25
18.3.2013, 3:05
15.5.2013, 21:23
кто знает другие варианты прокладки дроссельной заслонки MD 194578, а то цена 300 руб и 9 дней ждать. наверно есть другие доступные варианты и в наличии.
16.5.2013, 23:16
кто знает другие варианты прокладки дроссельной заслонки MD 194578, а то цена 300 руб и 9 дней ждать. наверно есть другие доступные варианты и в наличии. MD 184046 взял эту по наличию за 95 р. не совпадает только размер кольца внутреннего - примерно 1,5 мм подрубить по периметру. |
Текстовая версия | Сейчас: 29.4.2024, 16:00 |
