Evo 9 Drag STM Project DS9 - 8.63 New Zealand |
18.2.2010, 18:18
Зарегистрированный пользователь Группа: Член клуба Сообщений: 528 Регистрация: 8.8.2007 Из: Ленинград |
PROJECT DS9 FACTS AND FIGURES:
http://www.youtube.com/watch?v=o0pi7xSKM6g...feature=related http://www.streetfire.net/video/EVO-9-DRAG...-FOR_731734.htm Engine: Mitsubishi 4G63 Turbo 2.2 Litre Tomei billet crankshaft Custom billet aluminium conrods JE Pistons (Custom STM spec) STM competition balance shaft removal kit Baffled alloy sump HKS head gasket with STM O-Ring kit STM Drag spec head studs Ported cylinder head STM Drag spec cams Solid lifters Competition double valve spring kit Oversize stainless valves HKS adjustable cam gears HKS cambelt Mechanical cambelt tensioner Hypertune plenum with 90mm throttle body Turbocharger: Garrett GT45 based turbo with Tial Sport exhaust housing Turbosmart 60mm wastegate Custom stainless STM headers with full merge collector 100mm stainless exhaust 100mm intercooler 80mm aluminium intercooler plumbing Turbosmart raceport blow off valve Drivetrain: PPG 4 speed dog engagement gearbox Ikeya Sequential shifter with custom air shifter system Quarter Master triple plate clutch on custom flywheel DSS stage 5 axle kit (front and rear) STM transfer case Wheels: 15x7” Rays TE37 rims 24.5 x 8 x 15” MT drag slicks Brakes: Lightweight Wilwood 4 piston callipers front Lightweight Wilwood 2 piston callipers rear Lightweight scalloped rotors front and rear Hydraulic handbrake ABS removal Linelock system for staging Electronics: Motec M400 ECU Motec SDL sport dash logger Motec E888 expansion unit M&W PRO Drag 4 CDI Sparktech CDI coil-on-plug system Fuel System: 12 Litre fuel cell Twin SX 1000 HP fuel pumps SX fuel pressure regulator HKS fuel rail 1600 cc injectors Body: Lightweight fibreglass doors Modified front chassis Fibreglass bootlid 6 point NZDRA spec rollcage Racetech seat 5 point harness http://www.youtube.com/watch?v=o0pi7xSKM6g...feature=related http://www.streetfire.net/video/EVO-9-DRAG...-FOR_731734.htm Сообщение отредактировал Tony - 18.2.2010, 18:21 |
18.2.2010, 21:42
Просто суперский проект. Первый раз вижу, чтобы к эво приделывали пневмошифтинг. И колено не популярное в драге - томей 2,2 л ) Заморочились похлеще AMS, хоть результат пока чуточку похуже.
18.2.2010, 22:10
18.2.2010, 22:11
19.2.2010, 0:06
График интересный... Максимальный момент и максимальная мощность достигаются на одинаковых оборотах. Явно мотор недокрутили, побоялись. Мощность явно была бы выше.
19.2.2010, 0:28
19.2.2010, 0:48
Я это к тому, что для такой большой улитки 8000 об/мин отсечка - явный недобор. Плюс к этому ещё то, что завала мощности и момента на графике нет. Тоесть, крути дальше - будет больше ) Следовательно - недокрутили очень ощутимо...
19.2.2010, 21:11
2,2
19.2.2010, 21:39
что то на видео конец какой то неприятный... сильно драматично заглох мотор
20.2.2010, 10:00
"Ikeya Sequential shifter with custom air shifter system" Что за пневмо - примочка может кто знает? интересно ппц!
20.2.2010, 11:54
Custom. Тоесть сделанная на заказ или разработанная собственноручно.
20.2.2010, 22:08
Новый рекорд!!!!!!!!!
STM - Performance Vehicle Specialists In breaking news, today dave stock broke the world record for a late model evo. On his second qualifying pass dave busted out an 8.420 @ 167.6 mph, beating AMS by 0.002 seconds. Сообщение отредактировал Tony - 20.2.2010, 22:09 |
20.2.2010, 22:46
21.2.2010, 8:22
21.2.2010, 8:39
Офигеть. Только сказал, что чуть проигрывают они AMS-у, вот они их и объехали. Хоть и объехали на 2 тысячных, но всё равно красавцы. Американцы наверняка уже готовят ответ ;)
21.2.2010, 9:03
Офигеть. Только сказал, что чуть проигрывают они AMS-у, вот они их и объехали. Хоть и объехали на 2 тысячных, но всё равно красавцы. Американцы наверняка уже готовят ответ ;) Было бы круто! Собрать все эти Эвики(8-9сек) в одном месте,на одной трассе!!! Батл был-бы серьезный! |
21.2.2010, 10:47
Совсем корчануты.. телики отрезаны, лобовое пластик..
Тони готов? |
21.2.2010, 11:03
Было бы круто! Собрать все эти Эвики(8-9сек) в одном месте,на одной трассе!!! Батл был-бы серьезный! Может быть вы и сами знаете, но на всякий случай скажу. В Америке такие мероприятия приняты. Для любителей заднеприводных японцев есть Supra Nationals (проводятся каждый год, в основном участвуют супры, но так же есть и соареры, сливы, скаи заднеприводные, вайперы как главные конкуренты супрам и прочий многолитровы американские мускл кары). Для Эклипсов и Эвиков проводится так же раз в год DSM/Evo Shootout. Тоже очень крутое и масштабное мероприятие. Правда новозеландцев там наверняка не будет, но Америкосы между собой рубится будут серьёзно ) |
21.2.2010, 11:14
Совсем корчануты.. телики отрезаны, лобовое пластик.. Тони готов? Готовлюсь!!! Корчую себя!! А если серьезна то Димон прав надо всех собрать в одном месть и устроить трешь! Дэвид Сток Driver эво9 сказал что через неделю примерно они будут стараться еще улучшить время так как это не придел авто!!!! Я думаю мы им дадим бой и AMS и Bushur и итд! Сообщение отредактировал Tony - 21.2.2010, 11:15 |
21.2.2010, 11:22
Может быть вы и сами знаете, но на всякий случай скажу. В Америке такие мероприятия приняты. Для любителей заднеприводных японцев есть Supra Nationals (проводятся каждый год, в основном участвуют супры, но так же есть и соареры, сливы, скаи заднеприводные, вайперы как главные конкуренты супрам и прочий многолитровы американские мускл кары). Для Эклипсов и Эвиков проводится так же раз в год DSM/Evo Shootout. Тоже очень крутое и масштабное мероприятие. Правда новозеландцев там наверняка не будет, но Америкосы между собой рубится будут серьёзно ) Ну так ,то что Амеры между собой рубятся ,это хорошо! И рекорды по "чистому" времени в разных углах нашего мира! ,это тоже круто! Но собрать бы всех в одном месте, для очной борьбы ,вот это было-бы дело! Типа на чемпиона среди Эво!!! В мире!!! В Севастополе в августе хорошее международное соревнование намечается!!! Надо АМС,АВД,Бушура и Новозеландцов звать!!! |
Текстовая версия | Сейчас: 14.6.2024, 8:59 |
